t1704
Hello all,
Working on a new barstool kart project and wanted to poll the group on recommendations around gearing. My current plan is to run a 10T CC to a 54T sprocket using a #41 chain as I thought this would be a good middle of the road gearing setup (5.4:1 w/ 11' tires). As you can see in the pic, I'm cutting it pretty close with ground clearence and while I only plan to drive this on the street, a sizeable rock in the road or pavement variations could be a problem.
For now, I'll be running a bone stock predator 212 and this needs to be able to pull a 200lb adult without burning up clutches. Do you all think a 40T rear sprocket (4:1 GR) is too aggressive?
Thanks in advance for the insight.
