Gear Ratio? Big Kart, Big Tires, Small Engine
Brand new to karting and forums and wrenches.
Putting a Predator 212 Hemi on a fairly large off road, 2 seat buggy/kart. Governor removed, Upgraded Intake, Exhaust, Carb Jet. Stock springs, stock connecting rod, stock flywheel.
Ordered a Torque Converter kit with a 12T #35 and a 10T #40.
What's would be a good gear ratio if mostly used on flat asphalt??
What's a good gear ratio if used on flat to lightly hilly ground??
This used to be powered by a 200cc 2-stroke and has a 40 tooth sprocket.
I'm putting a 212cc 4 stroke on this heavy frame with a torque converter and 16" Tires.
Should I go 10T #40 / with 60T on axle?? Or 72T?? or 54T??
Wanted to use Lifan 420 but it wouldn't fit between the rear suspension easily. Not sure this engine will push this kart
Tonyzsi
Baltimore, MD
I agree. I have a YD3203 that is supposed to weigh just over 300 lbs. and I usually ride it on the street with my 2 kids so our total weight is around 300. I have a similarly moded Predator 212, my governor is still in and I'm running a 6.667:1 (9T JS x 60T axel gears) on 20" tires. The kart usually runs around my flat neighborhood @ 26 mph, but I have gotten a couple extra mph now & then. I'm going to 18" tires to get even more low end which I would then match your 10T/60T w/ 16" tires. I expect my ~600 lb. kart-(w/ riders) to zip around great with the 18"s and the same ratio you'll have.
Have fun!
-T
Thank you. This is the king of info I was looking for. Greatly appreciated
---------- Post added at 09:36 PM ---------- Previous post was at 09:34 PM ----------
Thanks. I was going to start with 6:1 and see how it went, but I figured I'd ask first before buying
Have fun!
-T
Looking to buy sprocket hub, sprocket and chain.
Will either #35 OR #40 be ok, or is the 35 too small???
I was concidering a ~$20 hub with 5.25" bolt circle
and a $15 two-piece #35 72T sprocket to use with the 12T #35 TC sprocket???
Will that be ok??
Atlanta, GA
72T/12T = 6/1 or 6:1 ratio. See Landuse reply above. #35 chain should be ok with an unmodified Pred, IMO.
Thanks. Ya this time I was wondering about the parts holding up. The 212 will be ungoverned, with intake, exhaust and carb jet upgraded. Still think 35 works?? And any input on the cheap two-piece sprockets??
Atlanta, GA
A little research tells me that the max working load of #35 chain is 400-450lbs, #40 chain is roughly twice that. If your kart is close to 300#, go with the #40.
Not familiar with "cheap two-piece sprockets". Where are you sourcing these?
Thank you so much.... I might want to get a 420cc later.
The sprocket I was thinking about was this...
http://vi.raptor.ebaydesc.com/ws/eB...877&category=175614&pm=1&ds=0&t=1452029357056
But maybe I'll go with a #40 set up. Thank you a bunch
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
The 2 piece Sprockets make it ALOT easier to change gear ratios in the future.
BMI karts has a good supply on their website.
If you are buying Everything new... I would go with 40 or 41 Both are readily available and the 41 is stronger than the 35.
Thanks I got the sprockets and chain for #41. Thanks very much. This forum has been very helpful. Thanks for sharing the knowledge
