Have you got a return spring on that throttle arm?
EDIT- umm... FLOOR!!!
Looks pretty good considering you're building out of free stuff & scraps! Nothing I built in high school looked that nice! My only comment/criticism is that your welds look a bit like playdoh (ie; they're a little on the cold side, either not enough voltage or too much wire)What voltage & wire speed are you using? Try 18V and about 180IPM. If you're already in that neighborhood with your settings then try traveling faster & draw little W's in the puddle, you may be happier with the results
And wear some feckin' gloves! Overall nice build, keep up the good work!
thats sick. it gets going pretty good.
now i wanna see jumps!
if you want to remove the governor, id get a billet rod.
second, i would gear it to go 40mph at 5,500 rpms, that way you can get even better acelleration.
