Full Suspension Contest Entry
JasonR
Here's my entry for the Build Off - I bought some bits and pieces for it a few weeks ago but this should give me the push to get it done! Spent all this weekend building the frame and will add pictures of progress shortly!
Jason
JasonR
This weekends efforts were bending the base of the frame and creating an engine mount:
JasonR
I also put together the rear base that the engine will sit on but i think i'm going to have to shorten the whole thing as it's a tiny bit too long...
JasonR
Cheers! Its only a hydraulic bender but I can now get perfect 90 degree bends from it without any kinking after filling the pipe with really fine sand.
bighead
Pacific Northwest USA
I do the sand as well. I fill the pipe with water. Then add the sand. This packs the sand into the pipe solid.
theo
I have bend many bends and the trick is to bend at 5 or more spots in the bend. Mark the center of the bend then place marks 1" apart on both sides of the center mark. Then do 2 pumps at each mark, do it over and over till you get the angle
JasonR
This weekends progress:
We managed to bend the top half of the frame and tack it together! It's now looking more like a buggy, even though I knew the dimensions it still looks huge!
bighead
Jason, What are you doing for the front end? I have an Odyssey front end. From steering wheel with controls to wheels. J-arms, hubs,spindles, steering column, steering shaft, steering wheel with brake and throttle controls, Extra long cables, Shocks, Skid plate, tierods the whole 10 yards. I even have the main bar on an old frame I can cut out and send with it.
Basicaly everything you see here in this pic but with a steering wheel. You could weld that huge man front bar into your frame and have front suspension. The Ody does not have much travel but it is a rocksolid set up. You can mod them easy as pie for wider stance and lots more travel
$50 plus shipping for everything. Shipping will be about $40 though. These are heavy duty parts. Look how many birds you kill with one stone???? Been begging a member to use an Ody set up in a build. $50 is a steal for what you are getting. I can even play around with flate rate boxes and drop shipping cost way down. I can pack the heavy stuff into a $14 flate rate box to cut down on the lbs. Then ship the bigger stuff in normal box.
I can cut the front of the frame off close to that main front bar. Then you will have to cut the tube out of the frame. The weld that tube/bar into your frame and your done. If you want to widen the j-arms I can send you a vid of how they did mine. You will have to widen the tierods but that is easy as well. Upper shock mount too. Or you can find a right size bar and make it as wide as you want without moding the j-amrs. (last pics shows this setup)
How much were you going to spend to get get all what these parts do? If you ever break or bend anything parts are cheap on ebay.
You were talking about how large it is? Notice how the ody sets the wheels back into the buggy? This may help?
If this does not work for you sorry for jacking your thread. I will edit it if you want me to. Just trying to help out.
JasonR
Thanks for taking the time to show me this - could you work out a final cost for it all shipped to me - i'm in the UK though and don't know how much shipping would be - all i know is it's real expensive to send heavy stuff out of the UK!
Would be nice to use the Ody stuff as looking through your collection it seems rock solid!
The idea of the wheels being set in further is tempting!
Jason
JasonR
Cheers! Just recieved the seat, bearings, axle and rear brakes so this weekend could be a good update!
JasonR
Loads done this weekend but i'll have to get back with photos soon! Just one pic to keep you going for now - the rear swingarm tacked together:
