tank placement? gravity feed? or should the carb be pulling? 6hp 4 stroke
N nlarr New member Messages 6 Reaction score 0 Dec 13, 2012 #1 tank placement? gravity feed? or should the carb be pulling? 6hp 4 stroke
Doc Sprocket ********* Messages 15,677 Reaction score 153 Location Ontario, Canada Dec 13, 2012 #2 Without knowing what kind of engine or anything else... Gravity.
N nlarr New member Messages 6 Reaction score 0 Dec 13, 2012 #3 with a true gravity setup its flooding out....
devino246 Official DIYGK Chem Nerd Messages 3,856 Reaction score 17 Location Lynchburg, VA Dec 13, 2012 #4 nlarr said: with a true gravity setup its flooding out.... Click to expand... Then take the screw off the bottom of the carb, drop the bowl, remove the float, clean the needle and seat, and reassemble. And FWIW, carbs don't pull. Gas has to flow into the carb bowl by means of either gravity or fuel pump.
Doc Sprocket ********* Messages 15,677 Reaction score 153 Location Ontario, Canada Dec 13, 2012 #5 Seconded. Most fuel inlet valves should be able to hold back 5psi- no gravity setup is going to exceed that. You need to fix it. Furthermore, if it floods with a gravity feed, it'll absolutely GUSH with a pump.
