Anyone ever install one of these?
Manifold Spacer, with Pulse Fitting.
Aluminum spacer with pulse fitting can be used either in front or behind carb. Run your fule pump without getting oil in it and/or having to drill into the block.
When used behind carb, dyno testing has shown up to 0.2 hp improvement due to longer intake tract. Improvement is over entire RPM range. Even if you don't need a fuel pump, this piece adds power.
Im still thinking about running a fuel pump,....It looks like this would do the trick...There werent a lot of details on the web site, would it work on a stock carb (6.5 blue clone)? would there need to be any other mods done for this to fit?
