I've got a 26" wide steel table I drilled holes in it, dropped some double nutted bolts in seems to work pretty good. the problem I have is my table has a little swag in it on one end. I have to shim up on one end, then I use a level to get it as close as I can. then I use small tack welds to hold each piece, just enough to hold it without putting much heat on it. seems to work for me ok. ( the table is 8" long its the back end off an old truck bed). when I finish I grind the tacks off the frame and table.
