Found the perfect welder! #6
oscaryu1
Thanks, Kenny!
newrider3 - Where should I get Pam from?
Eh, Well I've tried welding a carb bowl to the mower blade before... and yes, I burnt through the whole thing. :(
I'll be welding a electric minibike frame... I haven't decided on friction drive or chain drive with a... forgot that thing's name...
AutoMX
....clutch?
if you're welding a frame, get some tubing to practice on, getting decent welds on thick metal wont help you unless you're gonna weld big trailers.
oscaryu1
Tubing... do you have any "technical" specs I could have? So I can pretty much walk in, ask and get it? Thanks! :)
Last time, I couldn't find anything. Next day my dad went, came back with a $4 bar. Didn't know how he did it :p
kibble
I banned myself
You can get Pam at your local supermarket, where the cooking oils are. It's a non-stick cooking spray.
oscaryu1
Interesting... well next time I visit WalMart I'll remember! Pam and a camera... :)
AutoMX
tubing and metal stock is a standard thing, most hardware stores should have at least some in the store somewhere, it's no metal supplier but its enough to get something, a 4' square tube is prolly gonna run you like $12 but its enough to work with for starting.
specs are useless in something liek home depot, theyre prolly gonna have just 1 item anyway. a real metal supply place will def need specs, and a good standard size is 1" square tubing, with 16 gauge thickness.
oscaryu1
Well, I looked at the minibike tubing, and it's around 1/8" thick, and 3/4" diameter...?
Roy Vanas
demon since birth
welds anything!
AutoMX
basically a good weld will glow orange on the other side and not just be on the surface. it doesnt mean a perfect weld is flat on the surface, it will have the seam, but it will be fairly shallow and uniform and the weld will be penetrating some or all the way through depending on the metal thickness vs welder power.
oscaryu1
Eh, every once in a while one or a few of my welds would glow orange right after welding...?
Molten metal, that's where I'm not getting you. When I start making the bead, am I supposed to see both metals start liquifying?
