Found the perfect welder! #5
oscaryu1
Without doubt ;)
Can anyone post a pic of a fair ARC weld up here? I'd like to compare later on, see how I'm doing.
What can you tell that I'm doin wrong right now? :)
oscaryu1
Power... well all I have is "MIN" and "MAX" and the wire feed speed..
Thanks for that tip Kibble! I've been just moving it up n' down!
kibble
I banned myself
OH and that's another reason why sometimes it splatters, not enough being fed into it.
When it's too slow, it'll splatter like crazy and won't make a proper molten pool. When it's too fast, you'll burn through the material rather quickly. Try playing around with different settings and see what works best. Try doing similar motions and feed speeds while on the high and low setting to compare the two. With some practice, you'll figure out when to use what settings on what you're welding.
oscaryu1
Eh... High? That kinda scares me... I was told I'd rarely need to use high...
Well, everything I welded there, it was all below 2... Maybe thats why :D
I'll try that rainbow motion and playing around with the settings.
oscaryu1
Welp, I'm out to try the rainbow motion and mess with the wire feed speed. I won't mess with MAX right just yet.
Now comparing your welding vid with one of mine, mine doesn't sound so constant after all. I'll try a 3-6 and see if anything happens. I'll get more pics too!
Peace all, any more tips/comments? thanks!
oscaryu1
High? Are you 100% sure?
Some new pics:
kibble
I banned myself
Looking better, try it on high, it's really not THAT bad. Try to overlap each "rainbow" like in the second and third pic so that you don't have gaps between welds.
oscaryu1
Ok, I'll start on high and watch my time (so it doesn't overheat).
When welding, it should melt all the way through right?
Cause none of those pictured welds really do that.
oscaryu1
Welp, me go try on High and pray it doesn't trip da breaker. I'll take some more pics.
newrider3
Colorado
Slooooow down. You're moving too fast and not getting a consistent puddle. Really all you are doing there is piling up filler. When you are making a bead between 2 pieces, you need to wait until you can see them both melt together in one spot, then pull the puddle along the seam. Just move in circles in one spot, and you'll be able to tell the difference once they melt together. Once you're finished, it should look like they are smoothly joined.
oscaryu1
Thanks for the info Kenny and newrider3. It doesn't trip the breaker at high, but what stinks is that I couldn't separate the mower blades after that last welding, no matter how many times I pounded it with a hammer.
newrider3 - I'll try and use your idea and somehow combine it with the rainbow technique, and see which one looks better.
Tomorrow we're going to Home Depot to pickup some cheap steel and [hopefully] a line of quality flux core....
newrider3
Colorado
A 1lb spool of wire is about $10. A 10lb spool is only $40. The only problem is, the 10lb is way too big to fit inside the machine. I'm working on a mod that allows you to use the big spools. It involves old 2x4s, PVC pipe, JB weld and a drinking straw. :arf:
kibble
I banned myself
Ok, newrider3, if you're gonna post up that your "mod" requires all of that stuff, this forum requires that you post up pics too! :arf:
