Found the perfect welder! #3
oscaryu1
So... what setting on the knob?
And yes, it's the HF one. It was on sale for $49.
kibble
I banned myself
I just keep mine fast and the setting all the way up. There's really no point in changing it unless the spark was really soft, which it's not. :arf:
oscaryu1
Ehh... no idea. It's a bike frame. Thick enough to not bend when fallen, and thinner than a go kart frame.
oscaryu1
Harbor Freight shopping :)
crazycart
RedNek Engineering
MINNESOTA
I have found that bike frames are cheap metal and i burn through them most of the time on even the lowest setting, just give it a try, you will learn alot more from actually doing it than coming on here IMO..
oscaryu1
Lowest wire feed setting, and on Low?
Ahhh... manuals... I only read them if I have no choice. Guess I have to :smartass:
kibble
I banned myself
How about you get some scrap metal and use it to practice on? It's probably the best way to learn to use your new toy. You don't wanna get to working on something using the welder for the first time and end up saying :censored: !!!
oscaryu1
Scrap metal.... I have some thin angle iron. Would that work?
And how do I put in the darn wire? The instructions are very unclear. From what I see, remove the wing nut, the circular nut, put the wire thing on, take the end and place it in the hole there, and keep on spinning till it comes out the other end?
kibble
I banned myself
Scrap, use anything that doesn't matter much. Yes, angle iron would be ok.
The welder should have a roller inside, just past the little tube where you insert the wire. The roller propels the wire out into the torch.
oscaryu1
So ignoring those hard instructions:
1) Remove wing nut and the circular nut.
2) Place the roll on, and put the loose end of the wire into... the place past the tube? I'll try and get some pics, will do right now.
oscaryu1
Well... pics will come later. Ran outta batteries. The C875 is a helluva power hungry beast.
ed1380
Banned
ATL, GA
http://www.harborfreight.com/manuals/44000-44999/44567.PDF
page 12
unscrew teh wingnut from the roll.
unscrew teh torsion adjusting screw
place new roll or wire unto reel holder
start threading the wire where the red line is
screw in all the nuts and screws
unscrew the tip on the gun
turn on welder and be carefull and press trigger for it to feed the wire to the gun handle
screw tip back on
wala
kibble
I banned myself
What was wrong with my instructions? Other than the fact that I didn't have a pretty picture or anything? :arf:
oscaryu1
page 12
screw tip back on
wala
And I can start welding?! :eek::eek::eek::eek:
