Nodroz
Hello guys,
I've found a kart on the scrapheap yesterday. Everything is pretty much intact, but there is 1 rear tire missing.
I tried to start the engine, but I couldn't get it running so I put fuel directly into the combustion chamber. The engine fired directly but died short afterwards. I'll clean out the carb and see if the fuel-lines are good enough.
I need to make the kart higher, because I can't drive this on street now. It's too low to the ground. I'll probably do this with new bigger tires, if possible ofcourse.
Here are some pics:
The seat is a bit damaged, I'll see what I'll do with it later.
The chain is a bit rusty, so this will need a cleaning time also.
I'm going to get the engine running as soon as possible, meanwhile I'll be loooking on internet for tires.
Any comments or suggestions are more than welcome
EDIT: Sorry for the wong turned pics, I thought Photobucket turned them correctly..
Regards from Belgium
Nodroz
Here are some pics:
Nodroz
