anickode
Time and money seem to be inversely proportionate.
An old co-worker of mine always said that for any hobby, you need time, money, and space, and you will only ever have two of those things.
For a high performance build I'd take a predator over a briggs any day. But the one part tht could really make a predator do 50hp is a billet block and head. Think about it, billet head, block, crank, rod, flywheel, rockers, sidecover, and valve retainers. The only parts that wouldn't be billet are the valves and springs, the cam, the pushrods, the coil, the valve cover, and the bolts. And if you had a billet block and head, with larger head studs, you could run a turbo.
One of the many big things that gravitates me towards flatheads, is I don't have to worry about dropping a valve. Something absolutely catastrophic would have to happen for that to occur.
The predator or ohv in general has a more favorable angle when it comes to the ports, you can also get a lot more compression out of them, and ratio rockers are available as well.
The ohv’s have more power potential period.
I'm a little conflicted here, I was gonna start calling JTSpeedDemon "Boy Wonder"
Stolen from Facebook.
