Budget GoKart
Aka a kenbar
I was bored and some of you are too, so i challenge you to revive a forgotten flathead that is sitting in your corner taken apart or left to rot. i have a little flathead tecumseh i respect for lasting as long as it has i have taken the head off and it seems to be in ok shape it has awesome patina and i plan on trying a slide carb and trying to remove the clutch and govenor.
To do on the forgotten tecumseh:
Replace head bolts (with used briggs ones lol)
Attempt to remove clutch
Oil change
Wire brush old paint from block and covers
Try different carbs but probabaly make an intake
Attempt govenor removal
Port?
Go over small areas with dremel
Check spark
Fix pull starter engagement
Try to remove fly wheel
Ps. It doesnt have to be side shaft...
Decode progress: H50 (horizontal 5hp)
Oil change
Port?
Check spark
All the engines in my inventory already run.
