Take a better pic of that gear box and axle area? Need to see what going on there. (is it laying on the ground?) Also try to use that exhust if you can. The run so much better and all day with stock pipe. There ugly but you can make them look cool if your lucky. I was able to run mine right up the side. You got a good sled engine. Single carb air cooled works well on the Ody's. Does it have electric start? Also use that oil tank in your build. I do not like just using just mixed gas unless your a carb wiz. Run it as staock as you can. And get the engine as low as you can.
Missed this thread sorry.
The karts at a friends house untille we get moved into ours on the 27th. im living in a hotel till then, anxiouse to get to work on this beast and make some progress. have a great place to ride here in hi, with 400 acres of trails. checked that out yesterday. i plan to use everything that i have from the sled, gonna run it on pre mix to check the oil pump on the first run. then go from there and use it if its pumping good. i gotta get a fuel tank. It does have electric start with a small battery and yamaha ignition, i like that allot.
The rear axle will not bolt up at the moment due to the reinforcing the guy did. i think this is where he stopped. im gonna rebuild the entire rear end, i agree his welds are ugly, but like you said por 15 does wonders and a grinder with wire brush will clean allot of that up. Wanna do the rear suspension simillar to Frankies. Im worndering how the ride will be, i might go with bigger tires on the rear for more ground clearance, and this making it possible for more travel in suspension without bottoming out.
? with the front shocks disconnected from the j arm does the suspension hang? i was thinking about getting some 11" shocks to replace the front. looking to gain travel
? does the sled throttle connection need to be a push or pull cable?
? Are rear reduction boxs different between the years? Ive read the older ones where weak.
I do not have the other lever, im still not 100% on wether i wanna use the levers or get a pedal assy for the throttle and build a pedal from the quad mater cylinder and lever i bought for the 400ex disks and hubs.
Thanks for the help
Heres some pics of the gearbox i plan to use, sled belt, and two different clutchs for the 540. will probably use the yamaha one at first.
