Brandon1023
needs an oil change
This is for my 2005 Nissan Maxima (not your average go kart), but I know there's many people on here with great ideas, so I figured I'll post here as well. Basically, I rebuilt my Nissan's 6 cylinder and put it all back together, and mounted it. When it came time to bolt on the a/c compresser, I suppose I drove the (incorrect) bolt straight through the aluminum on the upper oil pan, causing a hole to bore itself, giving oil a passage to leak right out of.
What do you recommend? I'm not going to replace the oil pan, because I've spent enough money and time (2 months as of yesterday). I was thinking maybe I could jb weld the hole from inside the pan and apply plenty of rtv gasket sealer inside the bolt hole from the outside, once it's time to put the a/c back on. Any other ideas? Thanks.
