Fixing a hole in the oil pan
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
This is for my 2005 Nissan Maxima (not your average go kart), but I know there's many people on here with great ideas, so I figured I'll post here as well. Basically, I rebuilt my Nissan's 6 cylinder and put it all back together, and mounted it. When it came time to bolt on the a/c compresser, I suppose I drove the (incorrect) bolt straight through the aluminum on the upper oil pan, causing a hole to bore itself, giving oil a passage to leak right out of.
What do you recommend? I'm not going to replace the oil pan, because I've spent enough money and time (2 months as of yesterday). I was thinking maybe I could jb weld the hole from inside the pan and apply plenty of rtv gasket sealer inside the bolt hole from the outside, once it's time to put the a/c back on. Any other ideas? Thanks.
Clean the bejezzus out of the repair area with a good solvent like acetone, that doesn't leave a residue. Scuff sadn adjacent smooth areas, and re-clean. JB Weld from there. I think I would use the putty version for the first "coat", as your normal JB will likely seep through the hole.
I think JB is a quick fix. JB will hold, sometimes more than the rest of the car. I would however, take it to a welding shop(well, have a friend take you), especially one that is automotive savvy.
Is that a heli-coil in the threaded boss? If so that might hamper the welding, so a new one might be needed.
What's it gonna cost to have someone weld cast aluminum?
And I must say- I have had properly done JB repairs last the remainder of the vehicle's service life. I did a huge crack in the cooling jacket of a '81 mustang's intake manifold once. Lasted a ridiculously long time.
Brandon1023
needs an oil change
Took me a minute to figure out who this was.. Mr. 4WD with the homemade miracles. I searched the issue on the 6th gen Maxima forum and someone else was suggested the same putty from JB Weld to fix a hole in his timing cover, so I don't see how it won't work. I'll keep the non-residual solvent in mind, and with that being said, hopefully Walmart will have the JB Weld tonight. :wai:
edit: Also, let's suppose walmart only carries the liquid kind.. Can I try to stuff the broken part of the hole with something that will prevent the liquid from seeping? I'm going to look around for the cracked piece of aluminum.
mymumisaman
uk
Can't you thread the hole then thread a small bolt in there with some of that jb weld? Thread it in as far as you need then chop the remainder off ?
