First Kart!
Ice Man
Tyler Tx
Hey yall,
Totally new to the go kart scene, and have no clue what I'm dealing with here really... Three days ago, I bought what I think is an old Ken Bar Streaker Pace Setter with a 5hp Briggs Fun Power motor (with an animal recoil starter assembly from 2010?). It had an old Max Torque T10 3/4 #41 clutch that was completely busted, so I just ordered a new one yesterday. The kart only cost me 50 bucks, which seems like an OK deal? Sprocket has 60 teeth, half inch apart, so I'm assuming #41 chain? It appears I've got a 6:1 ratio... I have no clue if this is good or bad. Also, the sprocket is super close( . 5 inch?) to the ground. Is this okay or will it get in the way? So basically, is this a good kart set up for me and my 12 year old brother to have fun/ tinker with? What are some upgrades yall would do? Any advice on gear ratio I should run?
Thanks, Ice man
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That all sounds real good actually.
Except the 1/2in ground Clearance.
You can easily fix that with Taller rear tires.
6:1 is a perfect ratio. and with that you can run up to 15" tall tires.
Ice Man
Tyler Tx
Thanks Chancer. Good to hear I'm at least on the right track. Gonna have to look into those tires now!
Ken-Bar Streaker is a good kart, real sturdy and well made.
But...
Ice Man
Tyler Tx
Haha fair enough! This is what I have on me, will take some more tomorrow.
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
thread highjacking in progress please stand by.... long tyme no see Chancer....you get to Texas OK? ....but I agree with chancer.... He knows his karts...
---------- Post added at 03:09 AM ---------- Previous post was at 03:06 AM ----------
Nice HAT... YETI COOLERS ARE THE BEST. :cheers2:
My rear tires are 15 x 6.00-6. Right on the money according to Chancer. My front tires are 13 x 5.00-6. I believe that's the factory setup for tires. Looks like your front and rear tires are almost identical in size whereas it should have a hot rod stance.
Here's one like mine. It's definitely channeling the General Lee theme...
