Will it help with the strength of the frame? yes or no
Marginally
I just offhandedly was looking around and thought hey whats out there in the wooded go kart world. I goggled "wooden go kart with motor", ( w/o quotes) and came up with a few ideas about the subject.
OP- As much as I like razzing you about your "machine", I inherently want you to have a good ride and live to tell the tale, Herbaceous or metallic alike.
Here is a good ideas site,
http://home.comcast.net/~makeyourowngokart/prod01.htm
and another
http://www.snarpco.com/gokart/
another
http://www.kartbuilding.net/index.html
I mean it will hold the right angle while its being built, after that they would be completely useless
and another
another
You are going to need a solid axle running all the way through the kart. If this was metal, you could weld the bolts on like you want to use, but because of the wood, you are going to have to go all the way through
theres no other way?
I would like to refrain from buying steel tubes
Like I said before.
You can put one of those on each side, and run a solid axle,
or two on each side, and run stub axles.
