hi everyone this is my first go kart project and i need some help. ive done a good amount of research but still have a few questions.. ok so i have a pressure washer that i dont use with a gx390 honda motor.. so i looked around n found a go kart that id like to put it on.. i notice that the shaft is about 4 inches long or so on the motor.. now it appears to me that the clutch sits on the end of the shaft but i hear you want it as far in as you can get it.. how do you move the clutch further in on the shaft but also keep it from moving around? also the kart has what i would refer to as average go kart tires.. medium in the back smaller in the front.. what size tooth clutch do i need? im not after anything specific such as high top speed or fast exceleration i just want it to do what a average go kart does..
thanks for any help you all have!!
