Gopedude
update your profile with your location. we like to know where people are! especially when they say they live close to a cool parts store.![]()
Fixed
Just checked the gearing. 10:54 and 16 inch tires.
That is a pretty tall ratio with 16" tyres. You might have some issues with that. I would get at least a 60T sprocket
jackshafts are easy to make... just sayin'...
I am new to the karting world, so im not familiar with everything. Jackshafts happen to be one.
There are indeed kits. You'll have to look around. None of them are wooden... (sorry...LOL)
CVT's do require the use of a jackshaft, BUT- many CVT's are self-contained, and have a built-in jackshaft. So- If you chose a Comet Tav2 for example, you would need nothing else.
jackshaft is just 2 pillow block bearings and a shaft with 2 different size sprockets on it. you feed the big sprocket from the clutch sprocket, then the smaller sprocket goes to the axle sprocket - giving you a nice gear reduction for better torque and slower top speed.
simply decide where is a good location to mount your pillow blocks (someplace STRONG that you can run bolts clean through without affecting the integrity of the kart), making sure you can reach the clutch sprocket and axle sprocket (reposition the axle sprocket if needed).
there are several jackshaft calculators on the web. just use google to find them, then come back to the speed calculator on diygokarts to determine what top speed you will end up with.
It is one wheel drive.
Well i had to buy a new carb, chain and clutch then it ran fine.
The kart is a live axle setup, but only one wheel is attached to the axle. The other wheel can free spin on the axle, which is confusing me.
I noticed the wheel that Is attached to the axle has no nut and it appears that the axle is just screwed into the hubcap. The other wheel has more axle coming out, so it requires several washers and a nut.
I know that with a live axle both wheels should turn with the engine, but in my case only one is.
