Finally.
Jackshaft- Amongst other things, allows compound gear reduction to help get around the issue of impractical sprocket sizes. Here's one I built-
Gopedude
Keller, Texas
So are there kits that i can buy that bolt on to the frame?
Also, ive been thinking about installing a torque converter instead of using the centrifugal clutch. A torque converter requires a jackshaft right? How much would all this cost?
There are indeed kits. You'll have to look around. None of them are wooden... (sorry...LOL)
CVT's do require the use of a jackshaft, BUT- many CVT's are self-contained, and have a built-in jackshaft. So- If you chose a Comet Tav2 for example, you would need nothing else.
mysteryboy28
Lansing, MI
jackshaft is just 2 pillow block bearings and a shaft with 2 different size sprockets on it. you feed the big sprocket from the clutch sprocket, then the smaller sprocket goes to the axle sprocket - giving you a nice gear reduction for better torque and slower top speed.
simply decide where is a good location to mount your pillow blocks (someplace STRONG that you can run bolts clean through without affecting the integrity of the kart), making sure you can reach the clutch sprocket and axle sprocket (reposition the axle sprocket if needed).
there are several jackshaft calculators on the web. just use google to find them, then come back to the speed calculator on diygokarts to determine what top speed you will end up with.
Gopedude
Keller, Texas
Shame. I wanted the wooden route :idea2:
Gopedude
Keller, Texas
Ah ok. That makes sense.
I always try and point people to mckutzy's minibike thread when talking about jackshafts. He has some great pics of how he did his. Even though his was for a minibike, the concept transfers to a kart as well
http://www.diygokarts.com/vb/showthread.php?t=5461
If you get a self contained TC, then you will probably be OK with leaving the axle sprocket like it is at 54T (as long as the TC sprocket stays at 10T)
See that part of why I wanted to build my bike in the matter I did. I did some research to find out on methods of jackshafts and there use. I also incorporated a tensioner device to the JS(I needed it as I had Right side drive).
It will be also be some of the beefiest you'll find out there, I could use heavier chain but I dont really need to, it'll only be some sprocket change though.
Main points on a Jack shaft. Secure mounting, good bearings, adequate support and good bolts.
Fail on one of these(like using a wooden....anything; Mind you I have seen this been used but That was for cutting trees and it was about a 100 years old.) will most likely cause further damage and/or, up/to and including death.
Pillow blocks that are cast iron or steel, is the way to go. Dont use those "pressed steel bearing hangers" they are just for steadying a shaft on the length of a run, some also have a ball bearing races, but if the holder is crap that wont do anything good or better.
Bearings(pillowblocks) need to have the sprocket or what ever on the shaft as closest to the bearing for support as possible. You start moving it out, its going to warp the shaft eventually(especially if its less than 1") , and screw the bearings quicker than ever.
Dont skimp on the hardware, I mean ya home depot will have some better bolts in the bin, but look for the best you can get for your budget.
Key note. Dont skimp on drive line parts or structure. I have seen a few big machines get destroyed by inferior parts and design.... mostly cheap parts.
sorry a bit of a rant .... carry on...
Gopedude
Keller, Texas
Well i had to buy a new carb, chain and clutch then it ran fine.
The kart is a live axle setup, but only one wheel is attached to the axle. The other wheel can free spin on the axle, which is confusing me.
I noticed the wheel that Is attached to the axle has no nut and it appears that the axle is just screwed into the hubcap. The other wheel has more axle coming out, so it requires several washers and a nut.
I know that with a live axle both wheels should turn with the engine, but in my case only one is.
This is a common setup; if you look closely, there's probably a way to lock the other wheel to the axle too. Many people create this setup to improve the steering...
DFWRealist
Orofino, Idaho
Can you post a close up pic of the free wheel on the axle? The kart I just replaced the live axle on drives me nuts with the poor turning ability on pavement. I am wondering if it makes more sense to have it set up like you described.
