Gopedude
There's gotta be bolts somewhere!!!
Sounds like you're well on your way to getting it running... Nice!
It was held down with clamps... No bolts or screws at all. Very strange. Took me and my dad almost an hour to get it off tho
It was held down with clamps... No bolts or screws at all. Very strange. Took me and my dad almost an hour to get it off tho![]()
Wow... Well- at least you got it!
i got it to start after spraying starting fluid once again, and it idled for about 10 seconds, then died. Found out the gas line i put in, was crimped and when i moved it, it completey snapped off. Also, the little gas that came out when it was crimped, looked disgusting, even though i just replaced it.
Im trying to figure out how to take the tank off. it just sits on top and has no bolts attached to it. once i get it off, i will wash it out with fresh gas and go through the carb one more time, but this time ill make sure i clean all the little passage ways.
the little on off switch didnt kill the engine wen we switched it to the off position.
At this point, i think the engine is fine, and the clutch needs replacing.
Dont know about that "kill" switch.
Oops. My friend took the pics with his phone, thats why i had to put a link. Here are some. These pics are from the seller. I havent had the opportunity to take a good one.
thanks for all the help.That is a Manco 485.
It threw me off because, yours does not have the roll cage on it. Without the roll cage, it will give it a totally different look.
The pic I am posting is the 485 I had and just sold. I painted it red and had the seats re-done with new foam and vinyl. Also, I put different wheels on the front that are different than yours.
But if you look at the frame on both karts & pedals, wheel, etc ... They are the same.
On the carb issue, i think the centrifugal clutch is the problem here.
im going to gopowersports tomorrow to pick me up a new one.
Also, i cant find the front tires i need on their website. The rubber on mine are shot.
There is a green wire coming out of the flywheel are that is just hanging loose... i wonder if that wire would kill the engine when grounded.....
To check spark plugs..
1# remove plug boot
2# Remove plug
3# attach boot back to removed plug
4# grip plug tightly.
5# pull flywheel/press starter.
PROFIT!
To expand on what landuse said:
The Manco 485 that I just sold, I had the following parts on it:
-9 tooth jackshaft sprocket (5/8 bore)
-I don't remember how many teeth on the big sprocket
-Chain was a #420
-Clutch was a Comet 30 series
-Belt was the Comet 5959
BUT... Just pointing out that mine had the Tecumseh 5HP engine, not the 6.5. For the parts, I am pretty sure they use the same jackshaft sprocket, chain & belt (assuming you get the 30's series torque converter.
My kart with the 5HP topped out right about 30 MPH.
Here's a few pics of the one I had which may help reference a few parts. The one w me driving was just after I bought it and got it running.
Thanks for the extra info DFWRealist. It looks like you had a blast on that kart of yours.
As for the difference between the 5HP and the 6.5....I don't think there is one. They should just bolt right up the same way.
It was a fun little kart to run around. Now if I could figure out why I can't get my Bristers kart to go faster than a slow jogger... I would be all smiles
My kart right now is setup with a cent. Clutch connecting to a sprocket on the axle. I plan to jusf replace the clutch with a new one, because it sounds easiest and is my cheapest option.To expand on what landuse said:
-Chain was a #420
1# remove plug boot
2# Remove plug
PROFIT!
Just make sure you get the correct # clutch. Make sure it is the same as your chain and the axle sprocket. You don't want to come home with a #40 clutch and everything else is #35.
What is the gearing on the kart at the moment? You might want to change now while you are buying a new clutch if you need to
Your front tires look like 145x70x6. Those are kind of expensive. If you do have a 6" rim, you can get a different size tire and it would probably be cheaper.
