Finally.
Gopedude
Keller, Texas
It was held down with clamps... No bolts or screws at all. Very strange. Took me and my dad almost an hour to get it off tho :censored:
Wow... Well- at least you got it!
And, it took a half hour to get back on.
So we finally fired it up, and it idled great. Went to give it gas and the engine almost died from pushing the pedal. The kart didnt move and the cent. Clutch was producing smoke. Tried giving it gas again, and this time the rpms went up but the kart still didnt move. The clutch was producing a lot of smoke. Then we propped up the kart to where the rear wheels were not in contact with the ground, and the tires started spinning even though the engine was at idle. In addition to this, the little on off switch didnt kill the engine wen we switched it to the off position.
At this point, i think the engine is fine, and the clutch needs replacing.
Dont know about that "kill" switch.
DFWRealist
Orofino, Idaho
i got it to start after spraying starting fluid once again, and it idled for about 10 seconds, then died. Found out the gas line i put in, was crimped and when i moved it, it completey snapped off. Also, the little gas that came out when it was crimped, looked disgusting, even though i just replaced it.
Im trying to figure out how to take the tank off. it just sits on top and has no bolts attached to it. once i get it off, i will wash it out with fresh gas and go through the carb one more time, but this time ill make sure i clean all the little passage ways.
One of my karts has the 6.5 Tecumseh on it and it did the same things you described. I ended up getting a carb rebuild kit and that did it. The pin in the carb was not working right and it kept making the float stick. Cheap fix at least.
The gas tank has two mounting bolts on the side that faces the back of the seat. The back side of the tank on the bottom has two plastic pieces that slide along a groove that holds the tank in place. I think it vibrates too much but, it is what it is.
DFWRealist
Orofino, Idaho
Kill switch is easy to remedy at least. Just inspect the wires to see if there are any breaks or cuts on it for starters. If wire looks good, I would take the switch off of its mount and hook up another switch and see if that works. If it kills the engine, then mount the new switch and away you go.
If another switch won't work, then you know the wire isn't connected or in the right place... Tecumseh has the kill switch wiring next to the fly wheel. I mentioned this as the 3rd possibility because, its a pain to get that housing off and back on.
DFWRealist
Orofino, Idaho
It is a 485
Oops. My friend took the pics with his phone, thats why i had to put a link. Here are some. These pics are from the seller. I havent had the opportunity to take a good one.
That is a Manco 485.
It threw me off because, yours does not have the roll cage on it. Without the roll cage, it will give it a totally different look.
The pic I am posting is the 485 I had and just sold. I painted it red and had the seats re-done with new foam and vinyl. Also, I put different wheels on the front that are different than yours.
But if you look at the frame on both karts & pedals, wheel, etc ... They are the same.
Gopedude
Keller, Texas
thanks for all the help.
On the carb issue, i think the centrifugal clutch is the problem here.
im going to gopowersports tomorrow to pick me up a new one.
Also, i cant find the front tires i need on their website. The rubber on mine are shot.
There is a green wire coming out of the flywheel are that is just hanging loose... i wonder if that wire would kill the engine when grounded.....
Just make sure you get the correct # clutch. Make sure it is the same as your chain and the axle sprocket. You don't want to come home with a #40 clutch and everything else is #35.
What is the gearing on the kart at the moment? You might want to change now while you are buying a new clutch if you need to
J_Walker
Florida
To check spark plugs..
1# remove plug boot
2# Remove plug
3# attach boot back to removed plug
4# grip plug tightly.
5# pull flywheel/press starter.
PROFIT!
DFWRealist
Orofino, Idaho
My Manco 485 had these parts...
To expand on what landuse said:
The Manco 485 that I just sold, I had the following parts on it:
-9 tooth jackshaft sprocket (5/8 bore)
-I don't remember how many teeth on the big sprocket
-Chain was a #420
-Clutch was a Comet 30 series
-Belt was the Comet 5959
BUT... Just pointing out that mine had the Tecumseh 5HP engine, not the 6.5. For the parts, I am pretty sure they use the same jackshaft sprocket, chain & belt (assuming you get the 30's series torque converter.
My kart with the 5HP topped out right about 30 MPH.
Here's a few pics of the one I had which may help reference a few parts. The one w me driving was just after I bought it and got it running.
-Chain was a #420
Thanks for the extra info DFWRealist. It looks like you had a blast on that kart of yours.
As for the difference between the 5HP and the 6.5....I don't think there is one. They should just bolt right up the same way.
DFWRealist
Orofino, Idaho
Not all fun & games lol
It was a fun little kart to run around. Now if I could figure out why I can't get my Bristers kart to go faster than a slow jogger... I would be all smiles
Gopedude
Keller, Texas
-Chain was a #420
My kart right now is setup with a cent. Clutch connecting to a sprocket on the axle. I plan to jusf replace the clutch with a new one, because it sounds easiest and is my cheapest option.
Gopedude
Keller, Texas
Just checked the gearing. 10:54 and 16 inch tires.
qtband
St. Louis, MO
Your front tires look like 145x70x6. Those are kind of expensive. If you do have a 6" rim, you can get a different size tire and it would probably be cheaper.
Gopedude
Keller, Texas
Yep. And they were about $33 bucks a piece. I got some extra thick ones though. Luckily, theres a store a mile away from my house that carries every part i would need.
mysteryboy28
Lansing, MI
update your profile with your location. we like to know where people are! especially when they say they live close to a cool parts store. :)
