Remember that the key only provides an index for installation. With the flywheel nut torqued to spec, the wheel will not move.
use valve lapping compound to lap the 'wheel to the crank before final installation.
...I have had a flywheel key shear off on my old flathead during a hefty backfire, and I feel that filing one down sacrifices strength, even if only a little bit.
Having filed keys, sheared keys, lapped flywheels to cranks, etc myself, I'd say that you're both right.
The key is an assembly-index part, not much more. The friction between the crank/flywheel is what holds them in place, and the key is a sacrificial part to protect the crankshaft from getting twisted in case of a sudden 'catastrophic' engine stop / shock load. Filing down a key won't make the flywheel measurably more prone to moving, since the forces involved are far beyond what it takes to shear a key to begin with - in other words, the key is just along for the ride anyways, half a key makes no difference.
As a practice, I always try and move the coil as far to the 'advanced' (counterclockwise) position as its mounting screws will allow, sometimes that's a lot and sometimes it's nothing at all.
If you want more advance, you've then got to move the flywheel relative to the crankshaft by either filing, removing, or replacing the key with a special-made one (that somebody else filed).
Regardless of whether you want advance or not, I also generally lap the flywheel and the crankshaft - it's easy and believe it or not makes them easier to get apart (at least in my experience, I thing it's because there's less room for corrosion between them?). Just put some lapping compound on the crankshaft, put the flywheel into position, and turn it back-n-forth / around a bit. Remove the flywheel, wipe the compound off, and you'll see where the high spots (if any) are getting worn down. Continue until you've got everything nice and uniform, then clean it all up, wipe on/off bit of WD40 as corrosion-protection, install the flywheel wherever you want it, and
torque the nut to specs.
Seriously, 99 times out 100 that a key is sheared (not counting sudden catastrophic engine stops), it's because the nut was tightened "dang tight" by hand, which usually isn't enough. Get and use a torque wrench!
