Filing flywheel key.
r_chez_08
Should be in the shop...
Cornwall, UK
Hi,
I wanted to file the flywheel key to advance the timing on my g100 engine.
Firstly, what are the advantages and disadvantages of doing this?
Seconly, how do you do it?
Thanks
Rob
By filing the key down, you advance the timing. Basically, narrowing the key, you can re-install the flywheel slightly turned. Every .006" you take off equates to 1* of timing advance. Or retard if you turn it the other way. If the engine is stock, a few degrees of advance may help a bit. If it's modified to spin up well past 3600 RPM, that's where it really helps.
Work slowly and carefully, checking your work often. It may be easier for some people to just go buy a premade timing advance key. When you reinstall the flywheel, set it as far to the right (clockwise) as the key will allow.
I read somewhere (AGK, I think) that a stock GX160 flywheel has 4* more advance than a stcok GX200 flywheel, so if you have a GX200 or clone and you can get a GX160 flywheel free or cheap, that's an option.
r_chez_08
Cornwall, UK
Ok, thanks. It's a g100 but I am sure they are similar. What do you think of using a lawnmower flywheel on it?
Rob
r_chez_08
Cornwall, UK
Ok, just I have a lawnmower flywheel I salvaged from a crap Honda lawnmower, of a similar era, and hp rating.
Rob
My apologies for reviving a dead thread, I should know better:
I should know this but my brain is still asleep but, the filed area should be on the left looking at the flywheel end of the shaft, correct?
The filed side matters not. By narrowing the key, you can re-install the 'wheel turned slightly clockwise. A small gap will appear on the left side of the key.
:huh: It must matter. If the key is not installed correctly, the 'wheel won't turn. Also, if I turn the 'wheel clockwise, wouldn't the gap appear on the right of the key?
You've answered my question though; I need to turn the 'wheel clockwise :thumbsup:
jman231994
Australia
Nope it wont matter, its the side of the key remember, not the top, so its still sticking into the keyway. The one thing I can see is that if the flywheel slips at all on the shaft it will switch to a retarded position....hehe
Remember that the key only provides an index for installation. With the flywheel nut torqued to spec, the wheel will not move. Heck, some racers have been known to run without any key at all! Also, some folks will use valve lapping compound to lap the 'wheel to the crank before final installation.
jamyers
Buffalo Gap, TX
...I have had a flywheel key shear off on my old flathead during a hefty backfire, and I feel that filing one down sacrifices strength, even if only a little bit.
Having filed keys, sheared keys, lapped flywheels to cranks, etc myself, I'd say that you're both right.
The key is an assembly-index part, not much more. The friction between the crank/flywheel is what holds them in place, and the key is a sacrificial part to protect the crankshaft from getting twisted in case of a sudden 'catastrophic' engine stop / shock load. Filing down a key won't make the flywheel measurably more prone to moving, since the forces involved are far beyond what it takes to shear a key to begin with - in other words, the key is just along for the ride anyways, half a key makes no difference.
As a practice, I always try and move the coil as far to the 'advanced' (counterclockwise) position as its mounting screws will allow, sometimes that's a lot and sometimes it's nothing at all.
If you want more advance, you've then got to move the flywheel relative to the crankshaft by either filing, removing, or replacing the key with a special-made one (that somebody else filed).
Regardless of whether you want advance or not, I also generally lap the flywheel and the crankshaft - it's easy and believe it or not makes them easier to get apart (at least in my experience, I thing it's because there's less room for corrosion between them?). Just put some lapping compound on the crankshaft, put the flywheel into position, and turn it back-n-forth / around a bit. Remove the flywheel, wipe the compound off, and you'll see where the high spots (if any) are getting worn down. Continue until you've got everything nice and uniform, then clean it all up, wipe on/off bit of WD40 as corrosion-protection, install the flywheel wherever you want it, and torque the nut to specs.
Seriously, 99 times out 100 that a key is sheared (not counting sudden catastrophic engine stops), it's because the nut was tightened "dang tight" by hand, which usually isn't enough. Get and use a torque wrench!
:cheers2:
:iagree: Very, very true! (of course, I agree with the rest of it, too!)
jamyers
Buffalo Gap, TX
Good point - Yes, flywheels are part of the balancing equation on some engines (like old Buick V8's), but I'm pretty sure that most small engines are internally-balanced and that the flywheel itself is zero-balanced. That is, it's the same weight all the way around.
A Honda G100 may be different and have the flywheel as part of the balancing equation, I don't know about it specifically.
Knowing what I know about internal combustion engines, I'm sure the flywheel plays a big part in balancing out the internal engine componenets, specifically the crank bearings. I suggested moving something other than the flywheel to advance timing based on that. In my mind, an imbalace, albeit small, can wreak havoc on any engine's internals if run for a long time, especially if the RPM's are spun higher than the factory intended. I know these are cheap engines and all, but I for one hate spending any money on a toy and/or having it out of commision for any time, especially if it belongs to your kids.
I am 99.99999% sure that the flywheel (if dynamically balanced) is NOT a factor in the engine's reciprocating assembly balance. Heck, there's even a fair chance the 'wheel is statically balanced. I am also quite certain that retiming the 'wheel a few degrees will have such an incredibly minute result you'd need an oscilloscope to see it...
...Think about the thousands of race guys that not only alter their ignition timing this way, but even swap flywheels completely without re-balancing anything- with no reported ill effects. IMHO? Not worth considering.
EDIT- Now that I think about it, I cannot think of one example I have seen of evidence of balancing on an industrial engine flywheel...
EDIT- (again, LOL) I couldn't take it anymore... I checked a few 'wheels I found floating around. Both my Briggs Twin 'wheels each had one drill divot, presumably for balancing. The divots were not in the same location on each 'wheel. I still stand my my previous statements, though.
