Figuring Top Speed with Jack Shaft Sprocket
devilsfutbol17
Bellingham, WA
I just want to get some confirmation on how I'm figuring my top speed of one of my dingos.
The clutch has 10 teeth, the sprocket connected to the clutch on the jack shaft has 25 teeth, the small sprocket on the jack shaft has 9 teeth, and finally the sprocket on the axle has 54 teeth.
I have not modified the engine, real GX200, so I assume I get 3600rpms.
25/10 yields a 2.5:1 ratio. So when using the speed calculator on this site, at 3600rpms, my "teeth on clutch" value should be 3600/2.5 = 1440rpms. So I put in 1440 engine rpms, 54 teeth on the axle sprocket, then 9 teeth on the clutch sprocket, 18" tires. That nets 13 mph, does that sound right? It is the slowest of all my karts, but gets out of the whole really really quick.
I bought it in this setup, I don't know why it is this way but it is what it is.
The formula for jackshaft ratios is:
(JS IN/Clutch) * (axle/JS OUT)
I would also change that JS Out to a 15T. You will have a 9:1 ratio which will give you more speed. Just remember that you cannot go too high (like 6:1) with tyres the size that you have
Why not a 6:1, with 18" tires?
On my bike I have 24"OD spare tire. I have 12clutch/ 24 JS in/ 24 JS out/ 72 axle.
A 6:1 ratio.
devilsfutbol17
Bellingham, WA
I happen to have a spare torque converter setup that came extra with a different kart that I bought, so I just installed that instead and it seems to be working well. I just need to adjust the distance of the motor from the jack shaft a little and maybe get a different belt.
6:1 is fine with 18" tires on a torque converter right? That's how my two recently aquired dingos came stock I believe.
A 6:1 ratio.
Just from experience I have noticed that you need a taller ratio if you have tyres that size. It cannot account for all differences though. Some people seem to be able to get away with higher gearing with their toys. Your is a minibike while his is a kart :thumbsup:
