devilsfutbol17
I just want to get some confirmation on how I'm figuring my top speed of one of my dingos.
The clutch has 10 teeth, the sprocket connected to the clutch on the jack shaft has 25 teeth, the small sprocket on the jack shaft has 9 teeth, and finally the sprocket on the axle has 54 teeth.
I have not modified the engine, real GX200, so I assume I get 3600rpms.
25/10 yields a 2.5:1 ratio. So when using the speed calculator on this site, at 3600rpms, my "teeth on clutch" value should be 3600/2.5 = 1440rpms. So I put in 1440 engine rpms, 54 teeth on the axle sprocket, then 9 teeth on the clutch sprocket, 18" tires. That nets 13 mph, does that sound right? It is the slowest of all my karts, but gets out of the whole really really quick.
I bought it in this setup, I don't know why it is this way but it is what it is.
