Figuring out gearing with a CVT
r97
Measure twice cut once
Massachusetts, USA
Check out Mcmaster.com for hub sprockets.
I already checked, highest they will go is 7/8", finished and machinable bore. Like I said you could modify it like landuse did, but if you can avoid doing so you might as well.
sno-kart
Thank you guys very much for the help. Finally figured it out today. Was going to go with #50 chain and sprockets, but to get the ratio we want, the rear sprocket would be almost 10" in diameter which would possibly cause ground clearance issues. Instead, we looked more into #40 sprockets and found that we can get the same ratio using a #40 12-tooth jackshaft sprocket (this is the smallest # of teeth a #40 sprocket with a 1" bore comes in) and a #40 54-tooth axle sprocket (which is less than 9" in diameter). We have those as well as a rear sprocket hub and solid aluminum 1.25" axle on the way :)
Now we just need a chain... I know it was mentioned earlier in this thread that there are "cheap-o" chains out there... how do I know I'm getting a quality chain? I know I can go to TSC to get #40 chain, but I rather get 420 chain as I've read that its designed for higher speed applications. Any brands that ya'll have found to be solid? Thanks!
qtband
St. Louis, MO
All i can tell you is get a good one. My snowmobile engine blew through chains like they were plastic until I used a 520 chain.
