EZGO Golf Cart
2SlickNick
American Minibikes @ FB
Mesa, AZ.
bolted on. Most of it has thread/welded studs on the panels itself.
---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ----------
I also have a find a way too bring the black faded plastic back to life.
2SlickNick
Mesa, AZ.
Might as well... Living on the East Coast and with the winter snowstorms, this golf cart was left outside. Too many things need addressed before my family rides on it. Also I do not want it to look like crap when we move to Arizona.
Poboy kartman
Senior Moments Member
White Settlement Texas
I like to give most plastic a good wipe with lacquer thinner...(testing a small area first) ....
Home Depot had "Wipe New" on clearance for $10....so I bought a box...I believe it was for "outdoor equipment " or something....anyway, I tried it on faded Briggs air filter cover and it looks like new now...
Poboy kartman
Well...I went online and I found what I bought: it was wipe new home and outdoor.I guess I got a pretty good deal....it's $20 online..
I would definitely test for a good lacquer scrub down and if it can take it, do that..if not, then some of that wax remover paint prep spray stuff.
The reason being, Wipe New works better on a clean surface , if there's oil ,wax , or some other barrier between it and the plastic it will coat it, but it won't color up as well in those areas making the color less consistent.
I used to do the same thing with Turtle Wax F21 Super Protectant , but it would often take two or three applications that I would let sit overnight. I still love that stuff for a lot of stuff like tires, hoses, and interior plastics, but for all those, I pretty much dilute 50/50 with water. The result is less sheen. So....a tire looks like it just came off the rack, not sprayed with lacquer....And a brand new cars interior vinyl doesn't shine either....so it just looks new, not shined up.
2SlickNick
Mesa, AZ.
Well the weather has delayed UPS' delivery of my shocks.
So I started working on the body. The pic is of the front body panel. I won't have time to get it professionally painted or find a friend with a paint sprayer. So I decided to use rust oleum metallic blue. I laid down several coats of primer and wet sanded between. Doesn't look too shabby.
2SlickNick
Mesa, AZ.
Thanks.
No in the garAge. Then when if was dry to touch, i brought it inside to cure for 3 days.
Flyinhillbilly
The great cornholio
North West Arkansas
You might try wax and grease remover on the duct tape goop, it's had mixed results for me, sometimes it works, sometimes not so much, but it shouldn't damage the paint or
Plastic at all.
2SlickNick
Mesa, AZ.
I have been using a wire wheel to remove paint from metal surfaces and using this citrus adhesive remover on the plastic and rubber parts. It takes some elbow grease but has been working out.
2SlickNick
Mesa, AZ.
I did a few more things to the cart. I did find the rear wheel to be missing two wheel hub studs, thus leading to a broken rim - SMH... Luckily studs are easy to replace, available locally, and I have a spare rim.
I did get the rear body panel back on and more duct tape removed. Still a lot to do to improve this cart...
2SlickNick
Mesa, AZ.
Paint complete.
New carb, new belt, new throttle cable, new front shocks, and I still need a new generator belt - but will keep using until then.
Will upholster seats in a week or two.
Atlanta, GA
Nice work. Been following over on buggiesgonewild also. Those aluminum rear roof supports are inserted into the steel subframe?
Nick, the Marathons were known to have very sloppy steering. There is no adjustment to tighten them up. What ever you do, do not play with the governor on the rear end.I have replaced many stripped ring and pinion gears because some one wanted to go faster. :thumbsup: 12 years selling and servicing those things taught me those 2 very important things. Too bad it is not a 1988 on down you could ditch the governor then. Formula 2001 (fluorescent green spray bottle) by Turtle wax is the best stuff I ever found for shining up all the black stuff on a golf cart. The floor mat will be really slick though so be careful. A high pressure power washer is the best thing I found for cleaning the floor mat and cart in general. (mine is 3200 psi. at 4.0 gal. per min.)
