Engine won't rev past 5750 rpm's ???
Joe-405
Enjoying New Projects
U.S.A.
Yes I am going from a 14 tooth front to a 12. To help get the rpm's up. And I loosened the driven to get it in high gear faster. And I'm gonna try and buy the billet flywheel before Saturday also. I don't think I can swing the flywheel by then tho.
I'm sure this stock heavy flywheel isn't helping my cause one bit !
And correct 11" shifter kart tire
And I really think 80mph is achievable with some serious tuning and minor parts. That and I'm running vp q16 fuel which is oxygenated and makes just as much power as alcohol.
I can't remember your gear ratio to be honest.. what was that again?
14 to 12 [0.85 : 1].. that'd not work not even on the lightest of all mini bikes...
Anyways...
6250rpm I'd consider safe on a honda flywheel for a while
chinese flywheels... I'd NOT take that chance!
Frankly you spend a lot of money to build this engine and even more time to do so..
be patient and don't shred it to pieces before it's done.
PS the 'unadjustable' ARC flywheel comes with 8° timing advance build in, so keep your 0° stock woodruff key handy ;)
Joe-405
U.S.A.
It's 14 front sprocket 40 rear currently. But remember when you go smaller on the front you lose mph but get there faster.
And arc told me the big block non adjustable didn't have built in timing advance in it. Maybe I talked to the wrong person ?
Copied from website..........
Product Description
Our basic billet SFI Certified flywheel model for the Honda GX340 and GX390 engines. The keyway is fixed in the stock position and the stock pull starter can be used.
I also found a raceseng branded new one on eBay for $80+12 shipping.
Product Description
Thanks.. 40:14... 2.86:1 is already kind of a stretch..
in theory (IF the TC opens up to 1:1) that'd mean you'd hit 71mph @6240rpms
So yeah in fact it likely didn't :(
maybe 4o:12 will be enough (3.33 :1)
if your engine pushes 18 to 19 horses now, you might get away with that... but I'm not too sure tbh.
If ARC tells you there is NO advance timing in their flywheels for your engine, then there is none!
I think I rememebred a different comment in the arc install video (all past 09 are 8°) BUT it might as well be that he was only talking about the gx200 sized flywheels or I am just not remembering correctly what he said *shrugs*
believe their description and advice, that's the safest bet you could take ;)
if for some unlikely reason your flywheel still comes with a timing advance it'll be engraved on the flywheel itself! (as timing value like 32° or so) and you know for sure anyways :D
Joe-405 forgot his 6° timing key and had the stock one in. (which is 4°?)
GOOOOO JOE~!
Zero Degrees. The stock key is straight not offset, right?
on a 6.5HP, I think stock timing is 24 degrees. So the 6 degree key gets you 30 degrees, the 8 degree key gets you 32 degrees Before Top Dead Center.
I'm guessing the 420cc is similar????
Joe-405
U.S.A.
Not sure Bob
And it's supposedly around 30hp sid and my GPS said it was 58mph@6240 with tach. So maybe belt slip ?
KartFab
Dallas, TX
If you have the 308 cam, just use what the specify for springs, fuel, timing, compression etc
http://www.dynocams.com/item/308-gx390/cams-clone13/
Specs
Engine: 390cc OHV Clone 13HP
Recommended Class: Modified
Target (MAX) RPM: 7200
Spring Pressure (In / Ex): 48-50 lbs Dual Spring
Valve Lash (In/Ex): .003"
Ignition Timining: Pump Gas Not Recommended
110 Octane 32 Deg BTDC
Methanol 36 Deg BTDC
Compression Ratio: 12 to 1
Joe-405
U.S.A.
How did you figure this with a tc sid ? I got 7500@85mph. Obviously it was wrong.
Simple actually..
IF the TC (series 40 in your case) get's into highest gear.. it's a 1:1 ratio internally..
with your 40:14 sprockets the overall ratio is identical to your sprocket ratio (2.86:1)
and a 2.86:1 ratio with 11" wheels means you'd hit 71.51 mph @ 6250 rpms
and yes, that's 85.82 mph @ 7500 rpms closer to 86 than 85 actually.. but frankly..
under load (weight) the tyres collapse slightly so the effective diameter is a bit smaller than 11" soooo a it'll be less than that.
I don't see anything wrong with your calculation tbh (nor mine for that matter)
I can't tell what you will be able to achieve and what you will not be able to, I don't know anything about the engines powerband, torque curve or anything, so I don't even have anything to calculate from.
So anything I say about what ratio could work or not is coming "from the guts" more than anything else ;)
I still think that a 3.33:1 will make it much easier to get to higher speeds, do not forget that the torque will drop at high rpms on engines like these.. cam or not, timing advanced or not...
it's a combustion engine and the torque will suffer from revving up.
And it's torque that enables you to accelerate...
(that'd be 73.7 mph @7500 or 61.42 mph @ 6250 ; again a bit less due to tyre collapse)
TCs act a bit strange (first of all, they cannot transmit more than 80% of the engine power to the chain by design) so they have a lousy efficiency
(I think comets like series 20-40 are no more than 75% efficient tbh)
Best automotive CVTs barely reach 82% ..
that too needs to be considered when gearing IMHO.
Anyways, you need a certain amount of torque to accelerate and thanks to quadratic growth of resistances, the faster you are the more torque you need to accelerate further.
And we're back at the torque curve declining at higher rpms. to stop you from going past a certain (engine and ratio specific) speed.
With 13hp the max speed (limited by drag not gear ratio) will be around 67 mph.
with 18hp it'll be around 75.4 mph and so on and so forth...
I hope you can reach your goal.. frankly I hope you do not crash at anything like that speed even more, but that's a completely different topic ;)
Still: stay safe!
Your take off speed is about'ish okay with around 3.0:1 ratios.. still your belt will not like that too much, since it's a drag bike meant to get to speed quickly, that's not really an issue for a few runs...
but I suspect that after some time (even a small number of runs) the belt will have suffered enough to loose some of it's grip (thus even less efficiency and less top speed...)
So take a close look at the belt before each run just to be sure as much power will be transferable as possible.
Joe-405
U.S.A.
Thanks. Thanks guess we were correct in a perfect setting.
And I have a helmet, gloves, boots, riding jacket at the track.
It's all tuning from here on out so game on finally ! We are forecasted rain but hopefully I will get my shot for the track Friday and get some good videos up. It launches really good. If it launches any harder it might unload the rear tire. And I can add air in the rear also. I noticed it's definitely low on air.
This is from the Vegas Carts website
"These offset timing keys will advance the timing of your clone engine. 8 Degrees advance will bring the 440s to 29 Degrees BTDC.
Still Guessing. Now Second Guessing.
Their 440cc stock timing is same as a stock 420cc?
This is from NR
GX270 & GX390s (will provides approx 2 to 3 more degrees than shown)
6 Degrees - Gas Applications with ARC or Stock Flywheels
8 Degrees - Alky Applications
Joe-405
U.S.A.
Correct I think stock is 24-25*
So they are saying you need 36* is what I've read and I was at 31* still and didnt realize it.
I went from stock timing to a 6* key and gained 500 rpm and 10mph ! So it still needed alot more with my style fuel I am running. VP Racing Q16
