Engine won't rev past 5750 rpm's ???
Joe-405
Enjoying New Projects
U.S.A.
I'm stumped.
420cc clone
Cam for 7500+rpm
Billet long rod
No governor
32mm carburetor
HD valve springs for camshaft
It runs absolutely great but every time it flat lines at 5750 @ 49mph with a 100 lb. rider or a 170 lb. rider exactly the same every time.
Only thing I can think of is the stock timing ??? Any ideas. And it's not the rev limiting coil either cause it's a 1 wire and not a plug type coil.
Would like to figure it out before Friday so I can make my race.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Sorry for the obvious response... Gearing? no way right.
Didn't this have to do with the electronic rev limiter?
Did you try to rev it to 7500 on a stand? or with the tire lifted off the ground?
Like Denny said, maybe the belt or chain too tight?
I'm sure you aren't floating or bouncing the valves, right?
Heard you can turn the 35lb springs into 55lb springs by stuffing gx200 (or clone) stock springs inside the 35lb ones to make the dual springs. Might look into it?
Should we start the Ignition Timing debate again?
I feel unsatisfied with the way the last one ended (or didn't ).
What timing does the cam shaft ask for?
Where is our local expert FR15. Just send the bike to Texas. Problem solved.
FreeRunner15
I'm stumped.
420cc clone
Cam for 7500+rpm
Billet long rod
No governor
32mm carburetor
Cam specs ?
I'm not a pro yet but I am working on it.
So different driver weights and same exact max rpm...
Have you tried to test this on a downhill track?
Still the same rpm? then it's likely NOT a timing issue.
If you can get it to crack the 7k rpm going downhill it's indeed missing torque at high rpms.
and yes, that means you need to advance your timing.
I'd say go the full 8°, with an engine that size you shouldn't be too worried about low end torque on a mini bike.
But first
Take a few runs (as quickly as possible)
read your spark plug (could be too lean up there)
and check the coil temp
yes temperature.. (a laser thermometer would be great.. maybe borrow one)
if it get's hot (say above 80°C) it looses a good amount of power,
So one wire or not... it can still be limited (intentional but also unintentional by just not being up for the task in which case it'll get hot)
If it's hot, check and reset your coil gap, with a bit of luck it's just a hair too close and that's causing the heat (lack of consistent spark).
if it's just barely warm'ish and you know someone with a engine that reaches the 7000+ rpm maybe you can kindly ask to test your coil on his engine, just to narrow it down.
then go from there.
Mr. Spindle
middle tn
Like what 'sid said. It's all about heat. You can get a new plug that won't let it get so hot. Or an oil cooler;)
---------- Post added at 08:12 AM ---------- Previous post was at 08:10 AM ----------
Or some performance oil.
A laser thermometer would be handy too. Good idea itsid.
Nope.. MrSpindle you are misunderstanding the post.
I'm NOT talking about engine temperature
in fact some engines NEED to heat up rather high to be reliable on high rpms...
Cooling them with an oil cooler could cause the crankcase to crack. (differential heat cylinder vs case)
that's why many race engine like these industrial four strokes cover their shrouds air intake or cut off fins.
Hot or cool plugs are neither hot nor cool, refere to ONLY the spark plug temperature
it's ideal operating temp) but that does not transfer too well to the engine itself.
Engine temp is barely affected by the plug.
I was refering to electrically induced heat inside the ignition coil only (EMF)
very different thing.
Joe-405
U.S.A.
Cam specs are on the nr racing website. 306rpm cam. On 107 separation I think.
Not floating anything.
And I called arc he said it's timing. So I already have a 6* key just forgot to put it back in. I put the stock one in it. So I will try that first for sure.
---------- Post added at 09:09 AM ---------- Previous post was at 09:09 AM ----------
And no limit on the coil. It's ut1 style.
Joe as I said coils can be limiting without being a limiting coil..
The style is unimportant, the QUALITY is.
A low quality coil can fail at certain speeds.. that's not necessarily the case of course;
but do not rule it out just because it's a UT1 style coil.
(if it's not a fresh original Honda gx390 Or a PVL 12k coil ;).. then I'd rule it out myself :D)
Joe-405
U.S.A.
I actually think I have some at work. Will try genuine honda one also if I do. Thanks.
Joe-405
U.S.A.
Will a incorrectly wound driven cause this ? I think it's tighter than normal if I remember correctly.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
To sum this up a little so far. Sid suggested going all the way to an 8° timing key
ARC said it was timing.
Joe-405 forgot his 6° timing key and had the stock one in. (which is 4°?)
1 thing at a time before you GAB it. LOL
First the timing Key
Then try a different coil.
Then mess with Specially built TC
Tic Toc Tic Toc The race is coming up Soon.
GOOOOO JOE~!
Joe-405
U.S.A.
Thanks sid.................. Brain fart on my part obviously.
Now it's slipping the belt I think. Hahaha
6* timing key gets me 6240@58mph now. Getting closer ! Still not a 1/8 mile either.
That looks promising..
lap your flywheel (you do not want to shear the key, or worse ruin the engine completely)
and get an 8° key then.. I'm nearly certain it'll push you all the way to the rpms you expect ;)
but since offset keys do not have as much meat to hold an improperly lapped flywheel in place.. it's indeed a good idea to lap it correctly to sit nice and tight.
According to ARC (their flywheel installation video) there will be no need for the flywheel key at all if it's properly lapped to the crankshaft.
an incorrectly wound driven can cause troubles of course.. but engine rpm should be none of those.
if too tight you might not reach the 1:1 internal ratio so your speed will suffer..
but since you now reach 6250 rpm.. I'd say you should have that problem at all...
58mph @ 6240 (assuming 11" wheels) tells me you're reach an overall ratio of 3.5:1 roughly,
which I think means the TC works as intended.
Still,
a too tight spring though can slow you down a bit when it comes to acceleration, since the upshifting is delayed.
IDK.. but you might improve track times with going down a notch if your gear ratio allows that ;)
