The other day i was trying to hook up a throttle cable for a minibike i recently bought, and in the process of doing so i dropped a screw onto the flywheel and the screw stuck to it. i removed the outer case, and got the screw out, but now it seems that the engine wont go through a full rotation. i can turn the flywheel about 1 1/2 times before it gets stuck, and i have to turn it alot harder for it to get all the way through the cycle. i took out the spark plug, and it works fine, but when i put it back on it has the problem again. IF it helps i have the 6.5hp Harbor Freight Greyhound Engine
any ideas what this may be?
