Engine troubles, please help
CaptCanadia
Acton, CA USA
Yesterday I removed my gov and oil sensor and installed
18lbs springs. After I put it back together it started up no prob but with a high idle. On top of that the engine would stall out when I gave it gas. After about a minute or two the engine just stalled out at idle and would not fire again. I checked the spark plug and the torque on all the bolts, checked the rockers, and the fuel flow. I can not find out the cause for this it seems so odd. What do you guys think I should do?
You got me there. What I do want to mention is that you shouldn't run that engine now unless you have all billet parts inside. Those 18lbs springs are dangerous with stock internals
CaptCanadia
Acton, CA USA
Ya I know but I think I will be fine as long as I dont overrev it right? I almost have enough so in the next few weeks im going to get a billet con rod and flywheel and mikuni carb..but id like to get it running stock first.
