CaptCanadia
Yesterday I removed my gov and oil sensor and installed
18lbs springs. After I put it back together it started up no prob but with a high idle. On top of that the engine would stall out when I gave it gas. After about a minute or two the engine just stalled out at idle and would not fire again. I checked the spark plug and the torque on all the bolts, checked the rockers, and the fuel flow. I can not find out the cause for this it seems so odd. What do you guys think I should do?
