engine to clutch sleeve.
theo
Anyone know of a site where I can get a sleeve so I can go from 3/4" to 1". This is for the drive clutch.
Jcotz
...wasn't there
NY
Is it because you already have a 1" clutch? Because 3/4 clutches are much much cheaper than 1" clutches.
r_chez_08
Should be in the shop...
Cornwall, UK
Make your own.
Steel pipe:
0.76" ID.
.0120" wall thickness
1.0" OD.
Why .010" oversize I/D? Surely this is a bit loose, no?
I have made one of these with a grinder and a section of 1" pipe that was bored for me by a machine shop (for free).
I used a grinder disc on an angle grinder to cut a 1/4" slot and a cutting disc to cut a 3/16" slot. A dremel may be better, or better yet an end mill.
I would suggest welding the 3/16" key in, because on mine it loosened up because the slot was not perfect, wearing my crankshaft and the clutch a little by a rocking movement of the key. This may not be a problem if a mill is used.
r97
Measure twice cut once
Massachusetts, USA
Assuming both shafts have an ANSI keyway, you will need to make a stepped key (1/4" on top, and 3/16" on the bottom). If either the engine or clutch has a built in key (not a keyway) you will need to make a sleeve with two different slots for keys.
Hope that makes sense :/
