Make your own.
Steel pipe:
0.76" ID.
.0120" wall thickness
1.0" OD.
Why .010" oversize I/D? Surely this is a bit loose, no?
I have made one of these with a grinder and a section of 1" pipe that was bored for me by a machine shop (for free).
I used a grinder disc on an angle grinder to cut a 1/4" slot and a cutting disc to cut a 3/16" slot. A dremel may be better, or better yet an end mill.
I would suggest welding the 3/16" key in, because on mine it loosened up because the slot was not perfect, wearing my crankshaft and the clutch a little by a rocking movement of the key. This may not be a problem if a mill is used.
