BrandonF260Rem
I have a go kart that is fairly big. Two adults can sit in it with a little squeeze. I'm replacing the power plant in it, was a 150cc motor and integral gear reduction and torque convertor.
Lets say the kart with a rider(s) weighs 800 lbs to be safe.
Power plant will be a tuned up GX390. No governor, mild cam, a little head work maybe.
Question is will this gearing below have good take off (in your opinions) with a decent top end speed?
So engine to 40 series converter
with a 10 tooth
feeding a 36 tooth
36 tooth is tied on a shaft to a 16 tooth
that's feeding a 31 tooth on the axle
On the ground is 22inch tires.
with a 10 tooth
feeding a 36 tooth
