Engine Swap and Gearing Combo Questions
BrandonF260Rem
Central, TX
I have a go kart that is fairly big. Two adults can sit in it with a little squeeze. I'm replacing the power plant in it, was a 150cc motor and integral gear reduction and torque convertor.
Lets say the kart with a rider(s) weighs 800 lbs to be safe.
Power plant will be a tuned up GX390. No governor, mild cam, a little head work maybe.
Question is will this gearing below have good take off (in your opinions) with a decent top end speed?
So engine to 40 series converter
with a 10 tooth
feeding a 36 tooth
36 tooth is tied on a shaft to a 16 tooth
that's feeding a 31 tooth on the axle
On the ground is 22inch tires.
danssoslow
Louisville, KY
You're looking at a 5.54:1 ratio. Shoot for something higher if you're looking to pull a bunch of weight. 31 tooth on the axle is pretty small, is it on a live axle? What size axle is it?
5.5?
10-36-16-31 would end up being 1:6.98 almost seven;
A nice number for small wheels, for 22" wheels it's different (I'd say double that to 1:14)
Then again, there's a series 40 in this equation that would add another 1:2.43 for the lowest gear.
But a 800lbs kart/passenger *shrugs*
Nope, I don't think it'll be very useful at all for a good take off.
I'd increase to at least 1:10 on the jackshaft part
so let's say
10-36-10-31 (would end up in 1:11.16)
or
10-32-10-32 (would be 1:10.24)
with the TC that would provide a take off ratio of 1:25 at least, which I think should be a good ratio for a kart this heavy (with wheels this large)
danssoslow
Louisville, KY
5.5?
so let's say
or
My bad. I was using a formula found on eBay, and the math is wrong. The writer stated the two sets of gears as additive. That would explain the 8 people that gave the write up a "thumbs down".
Thanks for learnin' me something!
KartFab
These guys have already answered your question, but I just want to add that I actually have a large kart with a gx390 (stock), a comet 40 series TAV, 9 tooth jackshaft, 54 tooth axle sprocket, and 22" tires. Its got enough torque to pull me and my son up steep hills, and goes 40 mph.
