Nodroz
Hello guys,
I bought a used Kohler K181 8hp engine 3 months ago. The engine didn't run, as the seller said us. I cleaned the clogged fuel lines and carburetor. After some time I got the engine running.
Since then, I barely used the engine. A few weeks ago I mounted it on my gokart and fired it up. When I want to accelerate the engine start spluttering. I doesn't even have power to get my started. I thought there might be a bad connection cable to the ignition coil. I replaced that cable, because I've seen that cable was damaged.
Even when I replaced that cable, it still splutters and doesn't want to take off. After that, I thought the carb needs another cleaning. Today, I did that, but still the same result.
Spark plug has been changed and fresh oil added.
I think that the ignition coil could be broken, or maybe there is somewhere a bad contact in my circuit. Do you guys have some ideas, suggestion to help to fix this problem?
Regards,
Nodroz
Regards,
Nodroz
