Engine Shaft help please!!!???
dkscism
I just obtained a Tecumseh 3.5 hp Side shaft engine for free. It runs great and everything is fine and dandy except for one thing...the shaft. the motor came off of a pressure washer and the shaft is not long at all-mabey 1/2-3/4 of and inch LONG, not in bore size. It has no keyway and it is six sided like a bolt head or something.Here are some pics please give me your advice... can i mount a centrifugal clutch? or will i have to replace or add on to the shaft? here are the model #'s in case:
H35 45691X B
http://s133.photobucket.com/albums/q59/dkscism/?action=view&current=engineshaft2.jpg
http://s133.photobucket.com/albums/q59/dkscism/?action=view&current=engineshaft.jpg
anderkart
Surprise Arizona USA
Ah man that shaft sucks. Its just like a big old powered Allen wrench... ;)
If you dont really wanna replace the crank... I was kinda wondering if the pressure washers, water pump input shaft (and possibly its mounting/bearing supports) could be somehow modded/used to mount a clutch at some point further outboard?
Got any pics of the water pump input-shaft section?
dkscism
if im not comfortable with changing the shaft by myself, about how much would it cost for me to take it to a small engine specialist to get it done, including cost of parts?
dkscism
dang that sucks really bad...im just gonna try to find another engine. Can anybody hook me up for a decent one for under $100 in N.Carolina?
