Kaptain Krunch
Pro Junk Collector
The engine is a model 25442, Type 0215 01, Code 87012910.
It has a 1" Keyed shaft.
Now, I currently have a 6.5 tec on my kart now. Do you know if this will work without a lot of money to modify it? I know I'm gonna have to get a mounting plate, or drill holes to mount it. I just mean, as far as hooking up my torqaverter and what not. Thanks!
What bore is your torque converter? Other than that should be fine.
Its made in jan 12, 1987.
25CI block
It doesn't have electric start or a charging system
Pressure lube
Thats about anything useful i can tell you about it.
