I see that but I need help knowing what centrifugal clutch to invest in.
There's several clutch choices for a 1" bore 16hp engine, one of the biggest factors to consider is how many teeth the clutches drive gear has. They're available in anywhere between 10 and 18 tooth models, and for using #35, #40/41 or #428 pitch chain.
I own several similar engines using 1" bore clutches, I could help but you need to post more info first, like:
How tall are your back tires?
How many teeth does your axle sprocket have?
Where will you be riding? (off-road/hill climbing, or only on flat hard ground?)
How heavy are you and your kart? (post a pic of your kart if possible)
And finally what pitch does your chain/rear sprocket have? Here's a guide to measure yours:
