Engine RPM Help
rcarteraz07
Phoenix, AZ
I'm looking into the same engine. I'm not about the governor but here's the shaft dimensions on the listing.
Shaft Size: 1" Diameter, 2-3/4" Long, 1/4" Keyway,
Shaft End is Drilled and Tapped with a 3/8" 24 UNF.
r_chez_08
Should be in the shop...
Cornwall, UK
Remove the governor and do not worry. You can buy a billet rod and flywheel from www.arcracing.com if you want to be 99.9% safe. However, this is the rule I work by with hondas and clones- if you do not upgrade the valve springs, valve float will stop the motor blowing up. 5000rpm or so.
Jcotz
...wasn't there
NY
I cannot say that if you remove the governor, you will be 100% safe. If you exercise common sense and do not over rev it with no load for extended periods of time, then you should be fine. If you want to be 100% safe, then go with a new flywheel and rod.
tramont
Georgia
I see that but I need help knowing what centrifugal clutch to invest in.
tramont
Georgia
how can i figure out what is the top rpm
anderkart
Surprise Arizona USA
There's several clutch choices for a 1" bore 16hp engine, one of the biggest factors to consider is how many teeth the clutches drive gear has. They're available in anywhere between 10 and 18 tooth models, and for using #35, #40/41 or #428 pitch chain.
I own several similar engines using 1" bore clutches, I could help but you need to post more info first, like:
How tall are your back tires?
How many teeth does your axle sprocket have?
Where will you be riding? (off-road/hill climbing, or only on flat hard ground?)
How heavy are you and your kart? (post a pic of your kart if possible)
And finally what pitch does your chain/rear sprocket have? Here's a guide to measure yours:
tramont
Georgia
I wanted to ask is a jackshaft needed i wanted to just get a torque converter then run it to the axle
r_chez_08
Cornwall, UK
Yes, a jackshaft is required. Otherwise you will be geared for like 200mph, but you will just sit there burning belts.
tramont
Georgia
Thx for replying now that i know i need a jackshaft can you tell me how i would set it on my kart im going to upload pictures in a minute. also i wanted a 4:1 ratio is that okay since im going to have a torque converter.
South Kart3377
Kart designer
Va
4:1 are you crazy? No way even with a tc, if you want any bottom end or Non flat ground riding. Get a 5:1 AT LEAST, I THINK YOU NEED A 6:1 RATIO. With a 4:1 ratio you will be burning 40.00 belts in minutes. I know a 40 series is tough but thats asking way to much of it. (A 40 series is what you need for a tc)
r_chez_08
Cornwall, UK
Woah hang on there...
I run a 6:1 ratio with a 6.5hp clone and 19" wheels. Not an ideal ratio, but I managed donuts. Am I crazy? Actually that is highly debatable :roflol: BTW I am still on belt no.1, no wear visible yet. These 40 series tc's can take abuse...
He has a 16hp powerhouse-I would suggest you still gear 5:1 to 6:1 like southkart suggested, afterall you are removing the governor, you want to allow your engine to rev up to make use of those higher rpm. with a 4:1 ratio you could theoretically get almost 70mph. With a 6:1 you are looking at 45mph @5k- Plenty in a kart IMO.
As for setting up the jackshaft- install the 40 series driven on there, and slide into the bearings using lock collars either side of the torqe converter and bearings.
tramont
Georgia
okay thanks can you explain to me how i would mount the engine on the back i have pictures. also will i need 2 sprockets on my jackshaft?
