Engine problem .
Explicit Error
So yesturday i tried starting my engine but it wouldnt start . And after the 6th pull it locked and i couldnt pull any more .. What do you thing the problem is and what can i do about it ?
Thanks in Advance for all the help .
Explicit Error
Its a 5hp Briggs & Stratton .
model -135212 type -000601 code -93102007
Kaptain Krunch
Pro Junk Collector
vermont
time to take the head off and check cylinder and stuff. engines dont normally just lock up from trying to start. Does it have oil in it and everything? Was the governor intact while it was running? how long has it been sitting? its only a 93' should have plenty of life.
Explicit Error
I opened it up and it had no oil. Im guessing the people i bought the bike from didnt take much care of it . I took off the head and everything looks good to me beside the cylinder doesnt move at all.
oscaryu1
Take some PB Blaster or WD-40, and dump a bunch of it in the cylinder.
Take a large wrench, the right socket, and bust the flywheel over.
Briggs 5HP's are always like that. Plenty of stories where they seize it, unseize it, for a couple times before the rings go.
Remember the oil this time.
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Why would you do this if this if there was no oil?
An engine can jam up just from trying to start it dry.
It may not be actually seized but has jammed from metal shavings.
This especially common with Kool Bore engines.
Get the hone ready.
Explicit Error
when i opened the engine some parts fell out . heres some pics so that i can put it all back .
and my engine still is stuck . and cannaot turn flywheel
Kaptain Krunch
Pro Junk Collector
vermont
Crankshaft is the main shaft going through the engine. To remove it you must remove the connecting rod, which is the rod that goes straight up and is connected to the crankshaft. There will be two bolts on the bottom of it, you have to take those off.
THE HUNTER
"Ghetto Rigging Expert"
Detroit Metro Area
the parts that fell out are your camshaft and tappets. the side cover holds the camshaft in place, and the camshaft holds the tappets in place, so them falling out isnt a sign anything is broken, just remove the side cover more carefully next time to avoid dropping stuff, which can potentially cause damage.
as long as the bearing surfaces arent dented, you should be fine. (including the cam gears teeth, and the cam lobes)
and like Affair said, if you didnt get the flywheel off, put the side cover back on to get it off.
you want something to support the PTO side (Power Take Off, where you would put a pulley, clutch, ect) of the crankshaft while you are messing with the flywheel.
