Engine muffler and air filter
ApocGoD
Deus Ex Machina
Florida, Starke
Would taking the muffler off of my lawn mower engine do any good? What about a straight pipe? Also, if I added a larger air filter instead of the dinky stock ones, would that help any?
KieranM
Doin It!!
Kilkenny, Ireland
air filter would more than likely be better than a stock one, As for the muffler its not advisable to run an engine with out one cause its not very good for it, any upgrade you make should help your engine run smoother.
r_chez_08
Should be in the shop...
Cornwall, UK
if its a lawnmower, i dont expect the neighbours would be happy if you straight pipe it, and it wont do your ears any good. and the hp gains wouldnt be worth it on a lawnmower. if may make it run smoother tho?
solomon
ca
id straight pipe it and but a muffler at the end that you modified for better flow "cough" "cough" Drilled Holes "cough" "cough"
ApocGoD
Deus Ex Machina
Florida, Starke
Lol, the engine is going on a go kart. Just spent 4 hours rebuilding it. 12.5 Hp B&S vertical shaft. Running it with no air filter at the moment. (Was clogged beyond my belief) and stock 1 inch muffler.
ApocGoD
Deus Ex Machina
Florida, Starke
Would putting a mini K&N air filter on it help, or just make it look weird? Or a small carb filter?
Kenny_McCormic
Kartless....
Michigan Troll
Sit that engine on a shelf, in 10 years it will be the last surviving briggs 12.5, they have a horrible tendency to break rods(and destroy the engine in the process).
ApocGoD
Deus Ex Machina
Florida, Starke
Haha, yeah. Ive been running it at full throttle every so often and im pretty sure its going to blow soon. Thats why im fixing my B&S 26Hp. Mwahahaha. Its going on a mud buggy, 1 seater.
