What does everyone think of this set up a LCT 291 cc with govenor removed main carb jet increased to 90, less restrictive intake and exhaust. Do you guys think I need to switch out valve springs to 18 lbs because I removed govenor or no?
You do not have to upgrade anything internal if the governor is removed. The stock springs will cause the valves to float at about 5000rpm's, so the engine will not cause any failures. As soon as you want to upgrade the springs to say 18lbs or higher, then you will need to get a billet rod to avoid potential engine failure
