Just got my clone put back together, trying to get it running, it starts up no problem with the choke closed, but dies immediately once I start to open the choke....Any advice as to what needs to be done to keep her running?
You had the engine apart? Sounds like you need a new intake gasket. The reson it uns with choke it because its sucking alot of air in somewhere else, and when choking it, you cut off the air on the carb, and allow it to force more fuel. Replace the intake gasket and if that doesnt help clean the carb
So i replaced all the gaskets, gave everything a good cleaning, and it still seems as though Im losing vacuum somewhere once the choke is open. I do have an intake manifold with pulse fitting after the carb, so I can run my fuel pump, would it be possible that that is somehow causing a vacuum loss?
ok so we took off the manifold spacer/pulse fitting and it runs fine, so obviously it has to do with the pulse fitting. I dont understand why it wont run with the darn thing on there......darn thing....
So, there are new gaskets, everywhere there should be, clean carb, clean spark plug, we have gas, spark, compression...It turned over once, got going for a minute, died, and we cant get it to do anything now......
