Engine help
neebles
New Project
Illinois
Just got my clone put back together, trying to get it running, it starts up no problem with the choke closed, but dies immediately once I start to open the choke....Any advice as to what needs to be done to keep her running?
neebles
New Project
Illinois
Ill give that a shot, I just had it all apart and put it back together....So I will do it again
neebles
New Project
Illinois
The weird thing is, we had it running like a banshee 2 weeks ago, but it would die when we let off the throttle.....
neebles
New Project
Illinois
I have not tried to clean the carb yet, but as a back up plan any other thoughts or ideas?
solomon
ca
You had the engine apart? Sounds like you need a new intake gasket. The reson it uns with choke it because its sucking alot of air in somewhere else, and when choking it, you cut off the air on the carb, and allow it to force more fuel. Replace the intake gasket and if that doesnt help clean the carb
neebles
New Project
Illinois
Awesome, im ordering some new gaskets, gonna swap them out, Ill clean the carb while im at it......
neebles
New Project
Illinois
So i replaced all the gaskets, gave everything a good cleaning, and it still seems as though Im losing vacuum somewhere once the choke is open. I do have an intake manifold with pulse fitting after the carb, so I can run my fuel pump, would it be possible that that is somehow causing a vacuum loss?
neebles
New Project
Illinois
I will give that a shot. Also, we have noticed that when we pull off the air filter, there is gas pouring out of the carb......
neebles
New Project
Illinois
ok so we took off the manifold spacer/pulse fitting and it runs fine, so obviously it has to do with the pulse fitting. I dont understand why it wont run with the darn thing on there......darn thing....
neebles
New Project
Illinois
yep this kart hates me....
So, there are new gaskets, everywhere there should be, clean carb, clean spark plug, we have gas, spark, compression...It turned over once, got going for a minute, died, and we cant get it to do anything now......
