Davidgx200
I have a 6.5 clone, my setup is governor removed, 18lbs springs, gx140 emulsion tube,88 main jet, drilled low speed jet, k&n air filter and billet adapter, custom header, arc billet flywheel, 4degree offset timing key, arc billet rod 0.020" longer than stock, honda flat top piston and autolite ar3910 plug. Everything ran good as of saturday. I wanted to do more like always had my head shaved 0.045" , ported and polished. turned my huayi carb into a stock appearing carb venturi bored to 0.690" shaved throttle shaft and butterfly screw, 91.5 jet, emulsion tube drilled out and tip shaved to sit lower in the floor of the carb. when putting everything together i spun the engine to check clearance and interference. everything looked good. when trying to pull start it the rope stop and jerked me. I took the side cover off and hand turned it. One rotation was smooth the next was hard, so I took the head off and no marks of anything hitting compression release on cam seems to be fine. set valve lash over and over also. Turning with the head off was easy til I put pressure on the pushrods with my other hand then one turn easy the other stiff and real hard to spin. Sorry for writing so much but can anyone help me with this? Also is there a timing key chart or guide for mods or is it all trial and error? Anyone got a suggestion on offset timing key for this high compression setup? Thanks in advance.
