It may be salvageable with some serious elbow grease and possibly a rebuild kit, but step 1 is identifying it! You haven't told us what the engine is, and I'm not sure just by looking at the carb.
Good luck. I'm sure someone else can give you good news, but here is some bad news: the white stuff in the bowl is corrosion. If I remember correctly, even if you clean it out, it will come back because it has already started. Other members can correct me if I'm wrong, but that right there would be a sign to replace to avoid future headaches.
thanks but I am only 14 and 20 dollars there would mean 1080 bucks here. It would be a bomb on my pocket
Where are you located?
Im located in Dehradun, Uttrakhand, India.
